Janderso-
Thanks for the welcome and congrats!
The thing stuck in the head was the spacer for the drawbar- I got it out by taking a tap and lightly threading it, then screwing in a bolt, then using a long piece of round bar stock, tapping it out from the top of the quill housing. Took a few iterations as the threads kept turning loose. It's about 4" long, and hollow. For sure it's the spacer that sdelivery described just above. Without it the drawbar will not pull the collet up into the spindle. Just my bad luck that the dpo dropped it and the drawbar down the bottom of the spindle. It was precisely the diameter to slide on in then wedge in there good. I was worried for a bit till I figured a way to extract it.
The collets are R8 - they mount properly and I have an end-mill installed now-
I mounted a dial indicator on the way for the y-axis and measured the spindle as it was turning at minimum RPM. It looks like I may have 0.0005 max runout at the middle position of the spindle.
I removed the x-axis gib, nothing but filthy grease on there. I was planning on taking the table and saddle off and making sure all the oil lines were not plugged, now I have more incentive to do just that. No way to tell but I'm thinking this thing has never been apart for cleaning. It is truly filthy inside and out.
I have a video I can post of it running but need to figure out how to do that- apparently I can't upload directly to here - and I can't get it to come off my phone for whatever reason-
