- Jun 7, 2013
- 10,452
I had an experience with a Induma 1-S (very similar to a BP, made in Italy) the collet key was sheared off when I got it, and other work needed to be done, including replacing the quill because someone had tried to broach with it and sheared off several teeth on the quill, so I had to remove the spindle from the quill to replace the key, which was in the form of a countersunk head teat screw. After reassembly and a few months of use, it sheared off again; I decided not to worry about any more, that was perhaps 30 years ago, and it still is the same way and works just fine, but I never used collets, rather I used end mill holders where it is easy to hold onto them while tightening the drawbar. There was a thread on the subject sometime in the past, that came to the same conclusion.
