I do not suspect this is your problem, but its best to rule out the easy stuff first, have you trammed your tailstock bore to your spindle yet. You can have tailstock centered front to back just perfect but if your tailstock is high or low by more than a thou or so you can have problems, Usually what happens is people move the tailstock incorrectly. They loosen tailstock clamp and push it or pull it by top of tailstock at the spindle or handwheel. This tilts that tailstock and the soft cast iron base starts wearing on the hard ways, so tailstock drops, the factory knows this and most good lathes come 3 thou high but with spindle tilted down, so over time the wear get about 10 thou or so and rube decides to shim tailstock, so he puts a big ass shim in, and gets it kind of good, but now tailstock is tilted up and high. 10ee tailstocks are not the easiest to shim, but its doable, you will likely have to stack small shims in combination to get front and back more or less equal in height.
If its bed / carriage wear it can show as larger diameter near headstock or smaller, depending on which way wore, or more likely the back side oil line got clogged, so no oil to back way, back side of carriage wears against the hard bed and wears lower tilting whole carriage top, causing bearing adjustment issues on the 4 bearings you adjusted last week. To check for the important to me last 2 inches up near headstock, I like to chuck a piece of 3/4" brass, nibble east a quarter inch, down to 3/8" diameter now do the next quarter inch moving west, repeat till you have taken off a inch and half or two inches and see what your change in diameter is, this method should limit tool push off if you take light cuts with a wicked sharp positive rake tool. On a machine with as accurate a leadscrew as you have in cross slide, you should be able to repeat your place with a few tenths, so after taking your several cuts it should be good with in a few tenths of variations due to cuts. I hope this makes sense. This is how I was taught to check out a lathe, it is pretty certain to show if ways or carriage are badly worn up near headstock. If this test works out, then I leave about an inch or maybe a bit more of 3/8" stock sticking out of chuck and do it again down to a 1/4" diameter, if that is half decent I am good to go. This test takes about 10 minutes including set up, I did it repeatedly on the road when I checked out machines before purchase. If you think you have a real bad area farther away from headstock do same type of test using much longer rod and steady rest. In my experience you want to use as small a diameter rod as possible when chasing bed wear issues.
michael
