Here's an update, I started doing the body work on the Lathe bed. I pressure washed 2 coats of paint off then stripped the remaining 2 coats. Her are 2 pics back side bare metal front side all bondo'd up. I sand the bare metal to remove the surface rust then apply bondo. When I get everything bondo'd I will prime it with a 2 part epoxy primer. then prep for paint.
