Okay, it's been a few days and I hope you guys have had a chance to determine if you understand this tool angle and tool mod stuff. I just re-read it and there is a LOT there. I wrote it so I do understand it but something tells me that a lot of you do not. It's okay, I totally get it. Unfortunately, I don't know how to make it simpler than I did. Tool geometry is the key to lathe tool performance and if you want to grind high-performance tools then you need to understand this stuff. If something is not clear, then ask.
The other way you can do this is if I just give you the angles. I know that most of you should be able to grind a tool to specs by now. So far, I have given you the tool angles for mild steel, brass, aluminum and stainless steels. Not much left to cover - just the harder steels - but rather than just give you numbers, I would prefer we take a look at these steels and work out a design that one or some of you can grind and test. It really is simpler than it looks.
Heh, heh, so if you want a tool to cut tool steel or higher carbon steels then this is how you get it. You jump in so we can uncover confusion points and clear them up. Then pick a material and lay out the characteristics we need to accommodate. Then we'll design a tool together, meaning you choose the tool angles and I'll guide you but I will not tell you. If someone is willing to grind it up and test it, we can tag along and make suggestions for improvement and that would be an incredible opportunity for all of us.
We do not have to do this if you are not so inclined. However, it is the only way to have me there to look over your shoulder to make sure you're going in the right direction. So I will leave this to you and you guys can decide how you wish to proceed.
By the way, I talked this proposal over with Bonehead before I wrote the above message. His reaction was really interesting because his default is "snarky" but not tonight. He said that he has come to enjoy the responses and questions that have come up in this thread, many of which he had himself when he was learning to do this. He especially enjoyed seeing the tools that you guys have ground and sincerely congratulates you all. I again tried to get him to join the forum but he just flipped me off when his wife wasn't looking! In any case, with regard to my proposal above, he said, "Good idea. How else they going learn?" Seven Pidgin English words in a row is a lot for him so, with his approval, my offer stands.
