No, you're dead on. This is a severe amount of back rake and your hand is close to the belt so be sure to use a push block and concentrate. I do the rake grind in two stages - rough to get close and a bit slower to make sure I stop just as the grind reaches the tip.
You got this, T. You will really like this aluminum cutter.
Lots of rake indeed. Interesting. I might have to give thought to making the table go around the belt a little more for added control. I usually use another blank as a push stick, perhaps not the best choice. A 36 grit belt at 500+ SFPM is not something I want my fingers getting into. That thing removes HSS fast, I don't want to know how fast it removes fingers.
