Very cool, Bob! What do you plan to do with it? I assume it is off-road capable, right?
Plans.....? oh a few parades, military truck shows, already been down to Weare. NH
Very uncomfortable to drive, would need a full heavy load to deflect the springs as is it rides like a buckboard, semi COE gets very hot, so the engine cover needs insulation, found some ceramic felt to replace the asbestos pads.
Yes, it will go anywhere and has pulled out my Massey Ferguson tractor out of many ruts.
Nice for a pleasant back road drive in the Fall..... cruising at 30 to 35 MPH........ definitely not a highway machine so it gets trailer-ed a lot to out of town events. On real rough bush roads you get tossed around a lot.
The reality is the truck was design by the Brits, built in Oshawa Ontario, for the typical Canadian soldier of the time..... 20 years old, lean from the depression at 135 lb and about 5'6"......... and I am a modern Canadian 6'2" and 225 lbs......... you do the math!!!!!
If it had suspenders, I could wear it has bush pants.
Bob C
