I know we must learn to walk before we run, but, for the sake of this knowledge/thread, what about information on other lathe tools, like chamfer cutters and other form tools? It would be great to have the ultimate lathe tool info thread right here., complete with glossary?
Good suggestion, Emilio. Personally, I don't have a lot of knowledge about form tools but I'll give you what I know.
Form tools have a shape that produces a complementary shape. A threading tool is a 60 degree form tool with a positive shape that produces a precise complementary shape, a 60 degree thread. Similarly, a 45 degree chamfer tool produces a 45 degree chamfer. Both have zero rake and therefore cut with very high cutting forces. Accordingly, depths of cut must be relatively shallow and cutting speeds and feeds must be slow in order to avoid chatter. The larger the contact pattern of the tool, the greater the resistance or cutting force it will produce. In other words, the larger the contact pattern, the shallower your depth of cut must be and the slower your speeds and feeds must be.
With few exceptions, form tools are usually fixed forms that are stationary. That is, they produce a complementary shape as they are fed into the work but the tool itself is fixed relative to the work. One exception is a graver. It is a form tool with a flat top (more accurately, a side) but it moves, and this makes all the difference. A graver can "form" almost any shape desired because the user is able to change the approach angle of the tool at will. It can also take deep cuts at higher speeds and whisper-thin cuts at will. Of all the form tools I've used, a graver is one of the most useful tools I can think of.
Insofar as the tip geometry of a fixed form tool goes, the most common is a zero-rake or flat topped tool. However, you are not locked into this form. You can give a form tool side rake, back rack, scoop shapes behind the cutting edge, etc. What you will find is that due to the area of engagement, which typically enlarges as the tool is pushed into the work, cutting forces grow very quickly. This can lead to chatter and dig ins that can be rather energetic and dramatic. This is one reason why form tools are best fed by hand; power feed can have some pretty exciting results.
When grinding a form tool you have control of two basic geometry features: the shape and the relief angles. What works best for me is to first grind the shape I require and simultaneously grind a relief angle that cuts with the least amount of force I can achieve. One example of this is threading tool. If you grind such a tool with the standard relief angles found in a turning tool table, that tool will cut but it will produce a somewhat rough, cracked chip. The finish of the thread will also be rough. However, if you increase the relief angles the chip smooths out, as does the finish. When I experimented with threading tools, I ground tools with different relief angles and found that a 15 degree relief angle produced an acceptable finish while also having decent edge life. It is a balance, you see. I did the same thing with a 30 degree chamfer tool for dressing the end of screws and found that a 15 degree relief angle worked the best for me. Interestingly, the side of a square tool or knife tool works almost as well as my chamfer tool as long as I slow the speed down adequately.
The other thing I found is that when a form tool has a broad area of engagement, like a radius tool use to cut a half-round groove, the relief angles have to be increased or the tool will chatter severely. Here, it is a balance between cutting ability and edge life. Larger relief angles cut better but don't last as long so you can't have your cake and eat it, too. My suggestion is to start at a conservative relief angle of about 12 degrees and go up until you have a tool that cuts satisfactorily, then keep it sharp.
Okay, that's my take on form tools. I've made many of them over the years, when and as needed. They are useful to be sure but the main ones I have nowadays are my threading tools, tools for brass and my gravers.
