- Aug 2, 2017
- 20
Models arrived from Canada today' They look great. Awesome job on the packaging. Now, have to find some me time.
I can work on that. Shucks now I'm back at a 1,000,000, and 1 things to do again.....I would make a new platen from 1/4" thick steel. Make the base, weld the platen to it, then box the sides with flat plates welded to the platena and base. Then I would make the slot long enough to allow you to epoxy on a Pyroceram liner. A boxed structure should be solid enough.
The shorter length added to the heat, I am using a block, give it another shot tomorrow, sneaking up on it....Aukai, are you using a push block or just your hands?
Draw the line on top of the tool and keep that line parallel with the belt. As you get closer and closer to the line, it will be easier to do this. Take your time and grind one single flat using the push block to steer.
