- Jul 2, 2014
- 7,594
I see no reason to buy lanolin based rust preventatives premixed in spray cans or in liquid form at the high prices they get for them. Anhydrous lanolin is cheap on eBay. Mix it with some good oil (I use ATF) and with mineral spirits or some other solvent to the consistency you are looking for, and get to work. The lanolin needs to be carefully melted before mixing and the other ingredients should be room temperature or higher. You can easily make several different products for rough stuff that lives outside, and for fine metrology tools with the same three ingredients mixed in different ratios. It is not magic, lanolin is the best rust inhibitor, oil helps to spread it out evenly, and mineral spirits thins it for the thickness you want to apply. The recipe I posted is for machinist tools, tooling, and machine tables in the shop. YMMV.
