Remember that the wall to the house is already conditioned. Also, add good insulation, especially to the fixed thickness of the walls, not the cheapest. The ceiling can be whatever, as long as you aren't adding a floor up there. Good insulation pays for itself with both money and comfort.The BTU calculator says I need 32,000 at 78 degrees and 27,000 at 65 degrees.
