- Dec 27, 2014
- 4,083
One more time.
In your photograph of your work, it appears that the compound is parallel the clamping arm of your "Aloris type" tool block. If this is true, your compound is at the WRONG angle. You are feeding the tool at 60º, not 30º to the work. Lathes made in the US of A and lathes made in Europe/Asia start numbering at different points, resulting in different locations of the 30º mark.
Your comment about feeding less than half of the number of thousands suggested your error, (30º feeds more than half, nearer 80% of the distance). Chasing 20 pitch threads on 1/4 in rod, .001 is about all you can expect to get per pass, the load on the tool WILL deflect the work.
