- Apr 9, 2023
- 235
Oh, I also cleaned out around my lathe, which I still don't have up and running despite now having worked around that fact at least six significant times...
Pictured: Neglect.
Believe it or not, that's cleaner than it was in the past. Still completely filthy, but better...but also, in the middle of decobwebifying it, I found that I had a question: what color is this thing supposed to be?
Pictured: Seriously. I can't tell.
I think that at least three color layers; possibly four. I managed to break off a chip accidentally - as if there weren't a billion more in the immediate area, which happens every time I walk within three feet of it - and here's what I found on the back side:
Pictured: Looks like my elementary school bathroom...
Pictured: The tedium; it's above 9000. [yawn]
So, as best I can tell from carefully picking and prying the layers apart, it looks like they are:
1. Base metal.
2. Battleship Grey.
3. Light Grey that changed to creamy white under Layer 4, or creamy white that faded to grey where exposed.
4. Institutional Green.
5. Not-Quite-Delta-Grey.
6. Grease.
7. Dirt.
8. Regret.
9. Misery.
So, I assuming that the lowest layer over the metal - battleship grey - is the original, probably-made-from-pure-lead paint, I guess that's what I need to excavate...and I will need to excavate it: the paint just comes off in sheets, if you brush against any part of the machine in the wrong way, because that's what regret and misery do to paint. And - come to think of it - I probably could have just asked OpenAI/ChatGPT what the original color of a Heavy 10 is, and saved myself an hour of picking at lead dust...but then again, I programmed my ChatGPT to be Morticia Addams, so she probably would have told me to save the lead chips for a recipe. Wouldn't be the first time.
Pictured: I make such good decisions.
I mean, I kind of want to throw myself off a bridge, now ...but it seems like she got the color right. And in a way, this makes the entire mill situation more palatable; at least I only had to partially unchimp that machine...so, net gain? I don't even know, anymore; maybe I should just go back to looking for that press/brake.
Pictured: Neglect.
1. Base metal.
2. Battleship Grey.
6. Grease.
7. Dirt.
8. Regret.
9. Misery.
