- Nov 23, 2014
- 2,634
I started with a new Grizzly Rong Fu clone 35 years ago, paid around $1400 for it with power feed (similar to the current G0760). Upgraded to a used Jet JVM-830 knee mill about 30 years ago (similar to a Grizzly G0731 mill) for around $1500 as I recall. Sold the Grizzly for $1000. Upgraded the Jet with a 4-axis DRO for around $500 from TPACtools.com. I could probably get my original $1500 out of it as it currently sets.
A couple of months ago I bought a 1981 2HP Bridgeport Series 1 with a circa 1985 Anilam Crusader II 2-axis CNC control for $4000. Mill is in fantastic shape, and the CNC is pretty simple to learn (like Ted's EZ Trak). I didn't buy the mill because of the CNC, I bought it because of the quiet variable speed head, table with scraping still visible, Kurt swivel vise, phase converter, etc. The CNC has been great! As Ted mentioned above, I can't imagine putting my rotary table back on the mill as the CW and CCW arc routines are so simple to use. I'd never used or seen CNC in action before; it's totally changing how I do things (albeit only 2-axis at this point).
I guess the point being, if you buy something new and decide to upgrade at some point, you'll get a good chunk of your money back if you decide to sell. If you buy used and don't abuse the mill, you'll get out of it what you put into it. I you get something with more features that you intended to have, you'll use them. I don't think CNC is a "gotta have", but it's sure nice!
I use simple air for my chip control (if at all). Have a magnetic based segmented hose with a ball-valve for volume control. The ways are covered so I'm not burying swarf where it shouldn't go. I'm only 2-axis so I end up sitting in front of the mill anyhow. Brush chips off after a pass, then re-run the routine.
Good luck with your search!
Bruce
Bruce
