Hello,
I recently picked up barely used Bolton Tools ZX32GP (similar to a PM-727M or Grizzly G0795 bench mill). As the story goes, the previous owner purchased the mill and passed away. It has a 2017 date stamp on it, so it has sat for some time.
Grizzly parts diagram: https://www.grizzly.com/products/g0795/parts
Grizzly Manual: https://cdn2.grizzly.com/manuals/g0795z_m.pdf
I had been using it for some test cuts and noted the quill seemed stiff. It seemed to progressively get worse and now the quill will stay in position even with the return spring disengaged.
Things I have tried so far:
Thanks,
Ben
- Removed the fine feed worm gear assembly and cleaned it. The grease present was very stiff. Cleaned it all up and put new grease in place. Bearings for the worm gear are not smooth but they rotate by hand. Will do the bearings in the future. Slight change in the quill feel but obviously only when the fine feed is engaged.
- Fully extended the quill and degreased the outside. Worked the quill up and down to hopefully dislodge any debris. Oiled the quill body with a light oil (Starrett oil I had around). Greased the splines on the back of the quill for up/down movements. No change in quill movement feel.
- Greased the quill spline to see if the pin that rides in the groove is binding as I found in this thread. https://www.hobby-machinist.com/threads/pm-727m-new-mill-has-arrived.57473/page-12 . No change in quill movement feel.
- Removed the quill lock assembly completely (Edit: I realized later that half the lock was stuck in the head and was the issue). No change in quill movement feel.
- Dropped some Vactra #2 way oil down the top of the toothed spline shaft for the spindle. Ran the quill up and down. No change in quill movement feel.
- Disengaged/removed return spring. Made no real difference. The quill will stay in whichever position it was moved to.
Thanks,
Ben
