- Dec 18, 2019
- 7,115
I have a stock high pressure air probe used to fill an air gun. I made a drawing from it. I modified the part to help me install some o-rings, by drilling a blind hole into one end. It is unpressurized. However on the left side, the exterior (with the red) shows the area that can be pressurized up to 35 MPa. (~5000 PSI). Due to a brain fart, I used a 2.5mm drill mistakenly for the blind hole. So the thin 0.82mm wall is pressurized so that it would want to collapse the area inward.
I think Barlow's formula is for internally pressurized tubing. Is there some other formula for external pressurization? Can someone help me out?
If I have to destroy the part to prevent its use, I will. This question is for a stock part. I have no idea what kind of steel it is. It is NOT 1144. The steel is quite hard, harder than HSS. I have two damaged HSS drills.
Thanks for any and all insight.
