At the risk of coming across as an arrogant butt-head (or worse), I feel compelled to add a few comments. Please treat the following as constructive criticism, and not belittling or making fun of you.
I own a PM 12x36, and before that used a Grizz 9x19 for many years. I understand your excitement and your desire to learn quickly. HOWEVER, (and this is a big HOWEVER)--I feel strongly that you need to SLOW DOWN a bit.
I have watched a couple of your videos, and quite frankly, I was very nervous about your safety. For example: using your fingers to remove swarf (even the aluminum) while still cutting--extremely dangerous. Leaving the machine running while searching for pliers to remove the swarf (instead of using your fingers -- excellent choice) Parting off with the live center in the work.
These may seem like I am picking on you, but I am not--just pointing out a couple of things that jumped out at me.
On one vid, your tool was at least 1/4 inch above the center of the work. Another member pointed that out earlier.
I never observed you checking the parting tool for perpendicular alignment prior to parting the aluminum--it must have been close, because you were successful.
You stated that you don't know what the knobs do--the chart on the headstock does list the settings and the feed rates that those settings yield.
Please, please, slow down a bit and get to know the machine. Then start with the basics and advance gently--adding operations one at a time.
MrPete222 on YouTube (a retired shop teacher) has hundreds of videos covering every aspect of lathe operations. Mostly, they are very good.
If you feel you are ready for threading, I have a short treatise on that subject on my website that I created for the 9x20. It may be of value to you--it is not lathe specific. Here is a link:
http://www.akpilot.net/Threading Setup/Compound Setup For Threading.html
Again, please do not think that I am belittling you--I AM NOT. I really don't want to read a post from you about losing a finger or an eye.
Best to you, & enjoy the new machine
Jerry in Delaware
