- Nov 29, 2017
- 552
Put your compound mid stroke and zero it. Advance the cross slide and touch the tool to the work.
Move your carriage off the end of the work. Advance the cross slide the depth of thread and lock it in that position.
Now back off the compound move over and touch it to the work and adjust for your first depth of cut and continue cutting till you
reach the previously set zero. you will then be at the depth of cut you set initially.
I usually set zero on the cross slide also and use it to back off for clearance when traversing after a cut.
No trig involved.
This is the method I've used for several decades.
