Thanks benmychree, perhaps I will have to harden it. I will also be making a grease passage in the shaft. There will be 4 bearings total. I have to make a swinging v-block guide from scratch. That will pivot on the spinning shaft. That should be interesting .
If all else fails, I could go to bronze, maybe I'll overshoot the holes on the frame and have to change my plans. I already have the bearings.
Thank you!
