- Jul 9, 2014
- 613
use your moment thinking--- and before you cut the long slot out--use some fine emery cloth to finely polish the inside of the tube and only have the cutting section no more than half inch and the slotted about 2 or 3 inches---make sure the slotted out area is deeper than half the diameter---so the punch outs will spin out as you are cutting more------you won't get a hole in the center but you can use a little lubricant on the Id every so often to help them slide up and out easy---this will keep your press running without stopping for each piece---you can always solder a small angled piece on the inside to make sure they are forced out if necessary but if your slot is wide enough then they should eject with the spinning force---if your tube has a thicker wall--- then when you turn the id on the lathe turn the area just after the cutting edge a larger Id-----then cut out your long slot---they definitely will spin out easy then-------Dave
Yes ....gotcha ... " Brilliant " :thumbzup3:,
Now my only problem is .......where do I find a 40 mm ID bore thin wall smooth tube six inches or so long , that's why I turned the thin wall on the cutter .
I thought I'd cracked it with some new car exhaust piping but the diameters are ( so far ) way too big on the bits I've been able to source .
I may have to end up inserting a turned up cutter head inside a bigger tube and slipping some /drive /locating pegs in the circumference then glueing a turned cover /collar / sleeve over the drive /locating pegs to keep it burr free and safe where the pegs have been inserted . Then make the cut out slot in the bigger tube . Finally fit a turned insert with the driving flange & spindle to fit in the drill press at the other end of the tube.
:talktogod: I have an inkling that contractors construction 12 or 20 foot long scaffold tubes may be my salvation , along with judicious use of my 9 " long indexed boring bar & electric " Whizzer " cutter ...... Just got to beg , steal or borrow a short length that I can get in my car .:lmao:
