- Jul 9, 2014
- 613
I have a need to make a shape like an cup or drinking tumbler on the end of a 1 & 1/2 " bar of steel and once made and tested for correctness I'll turn a stem on the bar so it resembles a stemmed wine glass so I can fit the cup in a drill press and cut out zillions of foam circles . The cup's internal dia is 22 mm , OD is 24.5 mm with a depth 11 mm .
I've turned the basic shapes but found it very , " chattery " inside the cup and the finish inside looks like fish scales rubbed up the wrong way. On cutting out a disc the roughness makes it a bit too tight to remove the disc unless I stop the drill and use a needle to pick it out . If it were really smooth I think it will fall out as I raise the cutter
The tool I'm using is an overley long 3 " of ground round 1/2" square bar 1/4 " thick at the round part of the bar , it has a 1/8 th " purpose ground beak that is the cutting part . The boring bar appears to have been hand ground up from an angled left hand high carbon steel cutting tool
I've been using speeds of 500 for the external roughing out & 1270 to give a finish , 500 & 805 for the internal steel removal .
I've tried kissing it on the grind stone to get the cutting edge and angles in a reasonable state.
My questions are these ....
(1)
With the tool post on the right ...work on the left , bar boring the cup out towards the front/saddle of the lathe , I'm working blind ..I can't see the tool tip . Do I invert the tool put it on the back of the tool post at the center height and cut at the back edge /away from the front of the saddle . ( I have a crippling spinal injury that stops me leaning forward to see the tool tip inside the cup ).
(2)
On the tiny beak cutting tip , the actual cutting tip is almost good enough a point to run /turn a fine internal thread . Would my putting a 1/32 flat /slightly radius'd chisel point on the tip make a better less noisy cutter so I can use a few more thou to try and get a better internal finish ?
I feel that once I've ground the " beak ", the boring bar is only going to be fit for scrap quality high carbon hand forged steel as there will not be much of the beak left .
(1)
(2)
