- May 27, 2016
- 3,477
You point out what we often see on multi-meters, and some calipers. The number of digits precision of the display does not represent the fundamental accuracy of the measurement. The extra digits just change as "noise".Thanks for the links. Magnetic scales are far more complicated than I had envisioned. I was expecting a technology similar to that used for computer hard drives.
The error analysis has given me pause for though. Particularly the difference between high end and the low cost scales. What would concern me is that there is no practical way of knowing what the performance of a magnetic scale is prior to installation and trusting the word of a vendor who most likely has no technical knowledge of the actual function of the product seems rather foolhardy.
As pointed out in the second article, there is a difference between accuracy and precision. Just because we can read to six decimal places doesn't mean that the reading is an accurate display of fact. Unfortunately, we have a tendency to accept a digital display as fact without really confirming that for the most part. There is no value in having a DRO that can resolve to 1 micron of the displayed value can't be trusted to better than a thou or two.
Aside from a manufacturing or installation defect, I would be concerned with issuws arising from use. The possibility of ferromagnetic dust altering the pattern of the scale in an environment where such dust is commonplace is disturbing. Another disturbing thought is magnetic domains shifting. In the early days of PC's, hard drives had to be reformatted on a regular basis to avoid CRC errors and video tapes would fail after a time due to magnetic domain migration. Magnetic media is generally not considered a good long term storage solution.
Verifying a DRO scale along its entire travel would be a tedious task, especially if looking at the resolution down to a few tenths of microns. Were I to attempt it, I would probably use a set of trusted gage blocks in concert with a .0001"/div. dial test indicator.
Considering all that, I think I will stay with my capacitive scales on the lathe for a while yet. They may not have the precision but at least I am aware of their limitations
In the case of DRO(s), the common resolution of the grating I find is 5 microns, though available usually to 1 micron for very few dollars more. The digital display electronics, and displayed numbers is usually good to 1 micron regardless, and can suit both kinds. In metric units, if it sees a 5 micron type, the last digit is always a 0 or 5. In conversion to display inches, the minimum shift results in a number increment on the last digit that is meaningless, but of no consequence, because it represents about 0.00019".
I deliberately bought 1 micron gratings (for mill), and I use metric units, so the last digit does increment true. Even though the DRO may be truthful to 1 micron, I still can ignore the last digit anyway, because neither I, nor the machine with me driving its cutters, can actually make stuff to that precision. Two tenths may be standard fare for Stefan Gotteswinter, but I can only do that stuff in dreams!
I am thinking the glass scales are pretty much uncompromising, compared to how well magnetized regions on tape strips can be. Also, the glass ones have such economies of production numbers, they are affordable. My passing thought is "how do magnetic strips survive in the presence of magnetic chucks with leak fields orders of magnitude above what it takes to 'write to' magnetic strips"?
One aspect in the trade-offs you did not mention. It is the speed of the response. Some digital sensors deliver with a processing delay of some microseconds. It does not matter for a human using a DRO, but when it is the feedback for a CNC control loop, the instability can be devastating!
[ Edit: In this context, one has to avoid the phrase "economies of scale" ! ]
