- Nov 16, 2012
- 5,596
Dave,
I truly don't know if all mag chucks have oil in them. I've taken apart 7 units from about 4-5 different brands and all had oil. That's all I can say for sure...
Just yesterday, I noticed my 618 CERAMAX was stiff to operate. I flipped it over for about an hour or so (purely due to other things going on) and it worked fine afterward... It seems to help for the ones I have. I could indeed imagine newer ones having some sort of long-lasting synthetic coating or plastic that obviates oil. -Maybe, but that's just a guess on my part.
Ray
Ray
Ray--I enjoyed this forum and I have a question for you. are all walker 6x18 manual chucks filled with oil? I rebuilt mine and it had no oil in it at all. I had to design and make the shaft and cam pieces by myself because I didn't know any specs for them--well I finally got them made and used grease on all moving parts and put it back together. It works good finally but will not having oil in it bother it later? it was quite an ordeal of assembly/disassemblys untill I got the cam made to lift inner end of magnet and slide it just enough to line up without hitting end. I don't want to take it apart again unless it quits working. Dave
