I use the thin ruler technique for setting cutter height with the lathe, one minor quibble: Finding a suitable co-witness for the ruler that's known to be perpendicular. There are plenty things which should be, and may be perpendicular, like the headstock, but they aren't always easily co-witnessed with the ruler.
I searched for gages that might be compact enough to fit in with mini lathe size constraints, didn't find a thing. I have a few small round magnets and a piece of 5/16" diameter steel rod, maybe a magnetic-ended rod would be the answer .
Christmas Eve I faced the steel rod and using JB Weld, adhered the magnet to the faced end. Today I faced the magnet and did a bit of cleanup on the OD. Also spot drilled the magnet center to make a hole for any facing nub that might come up. The magnet may be a ceramic type, there are a few chips around the circumference. The face is flat though, and perpendicular to the rod.
I stood the rod on the lathe bed with a counter-facing machinists square, the daylight gap looks pretty good.
Here's what it looks like from the tailstock end. So far so good, we'll see if it really pans out.
