- Nov 25, 2015
- 9,779
Have you considered making a lifting plate. that way it's secured on 2 t slots. Its less likely to slip out
it can be as simple as an angle iron with holes in it for the t slot bolts and a hole for a hook in the middle over the center hole.
if you position them close to the center, you wouldn't even have to tighten it all the way, just enough that the nut is threaded fully.
