- Mar 13, 2017
- 36
The whole stock will be made out of aluminum. Why would you want to use parts from another stock instead of machining them in solid square and level?
Cutting the barrel channel is going to be a series of straight cuts. If I make the v-blocks an integral part the lengthy cut becomes interrupted, I'd rather mill pockets in a complete channel, which should be easier to make flat and parallel then a relatively intricate v-block. I also think the action which only contacts at 4 small points should contact steel and not aluminum, the blocks Ruger uses are very tough stainless. Just worried about slight wear due to recoil over time.
