Machined parts to attach a new knife handle for my daughter-in-law's knife
twooldvolvos
Oct 19, 2020
164
My daughter-in-law has her grandmother's kitchen knife which had a broken handle. She asked me if I could fix it. And so, I did.
First, I had to figure out how I wanted to do it. After some clickety clacks on my old computer, I decided to use Loveless bolts. As I began searching where I could buy some, a thought hit me. I have a lathe now so why not make some. Two sets to be exact.
Loveless bolts require a hole be drilled half way through your handles (scales) with a 90 degree shoulder. Then the idea is to put your Loveless bolts in the holes, tighten them up and trim to fit. Sounded easy enough. And it was after a few tries of course.
First I made some handles out of some scrap wood. I cut them close to size on my jig saw.
Then I made the bolts.
Next I found a drill from an old Dewalt set that had a starter point on the end. That worked to create the holes with shoulders.
So it was on to screwing the handles onto the knife. I put some epoxy on because this seems to be the way other guys do it.
After letting the knife dry over night, I trimmed off the excess brass with a band saw.
Now I was ready to sand the whole thing smooth. And Bob's your uncle. If you look closely you can see that the Loveless bolt leaves a "target" of concentric circles when sanded flush.
My biggest mistake in the whole project (or I should say one of my biggest mistakes) was using linseed oil for the finish. It went on nice enough but that stuff takes forever to dry. Maybe I put it on too heavy but dang. Its been months and its probably still sticky. How do I know? Because I painted my old vice with it after I did the handles and it is still sticky. No more linseed oil for me. P.S. My daughter-in-law was happy to have her grandma's knife back in working order.
That looks great!
Yes, loveless bolts are an amusing, sometimes awkward solution to the perennial problem of knife handle retention.
Yes, linseed oil can be sticky. Did you thin it out any before applying?
I used it on a bass guitar I built long ago but topped it with Johnson’s paste wax, that might help the situation.
Good save on a family heirloom, I have my dads old knives and will keep this in mind if I ever need to replace a handle.
John
