Looking for a suggestion for gear oil for the headstock of a lathe...
Problem solved. Thanks for all your help! (and nice call for all those who had it right the first time!)
You did the correct thing by researching more deeply. It is not a good idea to use something that will cause more harm than good, and well worth learning the differences.
Dredging up an oldy....
$30 at Tractor Supply, any reason not to use it in my Bolton 13x40?
John
@matthewsx it looks quite good. Might be even better for me, as my shop is *cold* in the winter.
Hydraulic oils designed for multipurpose use such as the tractor oil is perfect for the job. They are straight weight oils so pick according to temperature. I use Sino ISO 46. All manufactures have warnings if they shouldn't be used with certain materials.
Here's an example:
  • SPEC OIL HYDRAULIC OIL ISO 32, 46, 68, 100, 150, 220.pdf
