Extreme pressure (EP) gear oils will eat yellow metals (brass, copper, etc.) Lathe gearboxes often have brass or bronze bushings, clutches, and washers. Do not use EP oils with yellow metals!Here is what my manual says ('97 vintage 14x40). I would have to check but I believe this oil is similar to what I got at the time for the headstock gearbox from CDN Tire. The sight glass looks very clean but probably time for a flush for me too.
I also use the same oil that goes in from the side .......riiiight by that bank of electrical switches & buttons...... & flows into a felt padded tray right about where the #14 points to. That then somewhat distributes over the change gears below. Much thinner & it drips through too fast. Much thicker & it kind of hangs up in the felt.Your lathe might be newer gen, but anyway maybe helps.
If it is an Asian lathe use AW32 hydraulic oil. It is the correct viscosity, and AW32 meets the specs easily and costs much less than specialty oils. AW stands for "anti wear', it contains anti wear additives.I just acquired a 1440 gear head lathe, and I want to replace the oil in the headstock. What do you use and why?
As the saying goes, "Learn something new each and every day." This one is very pertinent.Extreme pressure (EP) gear oils will eat yellow metals (brass, copper, etc.) Lathe gearboxes often have brass or bronze bushings, clutches, and washers. Do not use EP oils with yellow metals!
