- Oct 11, 2019
- 139
and to add to the bad part it is not a LOCK on the chuck... it just makes it harder to unscrew yah 4 set screws of beefy diameter would be a better idea than just 3 and once all is adjusted scinch them all down very tight.... I seriously doubt you could cut anything in reverse that would make the chuck unscrew but it COULD ! ( i think the v belt would slip on my lathe before the chuck unscrewed with that mod !
the modification is all done to the chuck BP so another chuck swap would change nothing...unless you did the same mod to it... like a 4 jaw chuck probably would not need the mod. but putting a chuck on that had the modification would no doubt take longer ..... but for guys with chucks that have alot of run out, I am sure they would love the opportunity to correct the runout on chuck installation ! I know I would on my 3 in 1 .... LOL.....it's chuck is cheap and hasn't ran true in it's entire life
....but I don't use it for turning any more, I use the good lathe for that ! <GRIN>
bouncing ideas off one another has always been a fantastic method of coming up with a real good answer to the problem ! thanks for the input !
I went out to the shop about an hour ago only to find SNOW on the tailstock end of my lathe ! AURGH !
(at least I am happy that I left it drenched in oil ! )
when the storm is over I'll be out there with WD 40..... but a window that was covered over by a sheet of tin allowed in a bunch of snow... and the door to the shop is a big snow drift INSIDE the shop...... and that sux ! i gott'a seal that place up better !
first storm of the winter and it's a major blizzard .....go figure ! LOL.....
Bob........
Bob........
