T
Tom Griffin
Forum Guest
Register Today
Ron,
The upper nut pinned to the outer screw looks original. That would serve the same purpose as the inner threads on nut in the drawing I provided and would force the inner screw to do the initial lifting of the table. The lower pin hole in the outer screw could have been attached to a flanged collar, now long gone since it probably fell out the bottom when the pin broke, to restrict its upper travel. Everything makes sense except for the lack of a collar on the bottom of the inner screw. Without one, the inner screw would never turn the outer screw when it reached its upper limit and cause the whole assembly to telescope. Can you see the lower end of the inner screw?
Tom
Tom
