- Jul 16, 2020
- 29
I bought some link belt to run my belt head driven lathe.
I have removed 5 links so far but stile can’t get enough friction in the v pulleys.
The spindle head bogs down when cutting and slips with little force.
I have about the max tension on the belt and believe this is not the problem.
I belief the belt is a bit wide or my vees are a bit small.
It sits high up in the pulley.
I’ve been thinking, if I can get the belt into the pulley more and create more friction it should work properly.
Do you think that say taking a grinder and sand off a little of the side of the belt when it is running to narrow the belt some and make it seat deeper in the pulleys will work?
Better way of thinning the belt a wee bit?
These measure b belt but a bit weird. The old belt ended up riding way down in the vees a lot more before giving up the ghost, but still had more friction drive than this does.
Suggestions / fixes?
Thanks
Bruce
Thanks
Bruce
