I didn't want to re-level everything. Its a light weight, but that Sheldon horizontal still weighs about 1300 lbs. That back wall was real pain to frame, wire, insulate and panel behind that lathe. Now it hardly needs heating or cooling to make tolerable.
I started an album called New Shop under construction. I used insulated structural panels and framed the roof. I should used the roof panels as well. I would only need a light bulb to heat it! Still waiting for the bay door and siding to finish the exterior. The walls were up in less than 2 hrs and the complete box done by noon with roof done before 4pm.
It will used to house the lathe, motorcycle etc and snowblower in the winter, which is now.
Now that I've hit 20 posts, let's see if the system will let me post my shop: just ordinary two-car garage. Of course, nobody here would waste a perfectly good
garage by parking a car in it....usual stuff, Grizzly 1031 lathe, 1018 mill, surface grinder, Miller 180sd tig welder, 7 inch bandsaw, etc. :tiphat:
Actually not, it's a hobby shop so it's not in use all day every day...if I forget and leave the lights on (I like a well-lit work area) I feel guilty, but nothing there draws a dreadful amount. And rates are fairly reasonable here.
Nicely organized shop Kenny. That Clausing 4900 really brings back memories. The vocational program I attended in high school had them as well as the high school that I taught at. I literally know them inside and out.
