Cheers @wa5cab that makes sense. Now I sort of have my head around the gear selection process I’ll set it up for turning but maybe I’ll keep the gears for threading marked up somehow and set it up for slow feed turning. Makes perfect sense now you mention it!
@timmeh funny you should mention this as I was up the garage till gone midnight last night, initially to try and change out the gears then I got a little annoyed with the minor amount of backlash in the saddle so took the saddle off for inspection and when I removed the lead screw I noticed the gearbox had an issue. There is a hairline crack along the top alongside the banjo but it is still in serviceable condition, however, I found the yoke which selects forward /reverse doesn’t hold the transfer gear in the central position. I found one of the little fingers which push the transfer gear was missing!
I made one up from a piece of 3mm wall steel box section with a 3mm pin.
You can see in the straight up (N) position that the yoke doesn’t hold the transfer gear perfectly central.
This item was missing its pair!
I have made and fitted the finger follower but have not yet reassembled things. If it cures my ills I’ll post a full thread explaining the repair for others if required.
