Lathe taking a deeper cut then dialed in on the DRO.
Deleted
Good job on the washer! Your second picture shows how they got their spacing messed up at the factory. That hole for the adjustment screw should be about .050-.060 to the right and it would capture the gib as it should. It looks to me that a new gib wouldn’t solve a thing. At this point your fix is the best solution for the least effort.
Take the time to make yourself a solid tool post, you’ll be glad you did. I only put my compound on if I need to cut a taper, so it’s rarely on the machine for my use so far. One advantage that I have is that my used machine came with an Aloris BXA QCTP and I had already acquired a used one before getting the lathe. So I can leave a QCTP on each setup making the swap quicker. Might be worth watching the sale section here for a deal.
Just an update on my learning process. I want to say thanks to all who responded to start with and a special thanks to @Lo-Fi for bringing Stefan Gotteswinter's YouTube to light.
I have been slowly as time allows playing on the lathe turning a piece of 2" mystery metal down to 1.5". I have been taking it down at .075 thou at a time in three passes. The first pass at .050 thousand there abouts and then the next two passes (depending on where I end up after the first pass) .012 thousand. I have been able to hit my goal within .0005 the last four times in a row.
I'm still surprised at how much more is removed when taking a .050 thou cut. For instance, the last cut I set the DRO to .048 thousand and after that cut, I had removed .052 thou. The next two cuts were .012 and .011 and nailed it perfect.
Anyway, Thank You to for all the help! I have been struggling trying to get consistence numbers. I think I'm on the right track now.
Tim
Fantastic! So pleased you found it helpful :)
As another well known youtuber would put it: everything is a spring! No matter how solid it looks.
The other major advantage of the balanced cuts method is getting good finish off carbide, particularly in hard material. When you can't "sneak up" on a dimension and need a decent cut to get a good finish, it's really the only way. Taking a 20 thou finishing cut knowing you're going to hit your number and get a spectacular finish right off the tool is seriously satisfying.
