I posted some general threads about the woes I've been through in setting up my lathe after moving it cross country. I've finally gotten everything together and done the 2 collar test. I was able to get within .002 - .003 over 6" before I ran out of adjustment on the feet.
I'm posting this here because while I feel that is good enough for most hobby work, I really don't know if it's good enough for gun work or if I need to continue to chase that last .001.
I will say I am not convinced it's a bed twist issue. The surface finish on the unsupported end is a lot rougher than the headstock end. This indicates some flex, somewhere, to me. (I did take 3 spring passes to get to a point where the tool traversed the length but did not cut).
The lathe is a Romi/Doall 13x20 w/ BXA QCTP, 1/2" HSS tooling.
The test bar was a length of 2" aluminum.
Thoughts and suggestions welcome.
Thanks!
Thanks!
