- Dec 20, 2012
- 9,422
Good for you, Tony. Glad you got this sorted, finally.
With regard to grinding tools, I would recommend you decide on which type of grinder you are going to use and make yourself a good tool rest. I much prefer a good belt grinder but admit I am in the minority in my choice. Be sure your tool rest provides support around the right side of the wheel or belt to provide support for the bit as you grind in the back rake on a tool. Keep in mind that the most critical angles on a tool bit are the ones that rely on the tool rest angle - the relief and side rake angles - your table must allow you to precisely set and control those angles.
As you have found, a good tool can make a big difference in how the lathe itself performs and you are off to a good start. Now you need to individualize your tools to your specific lathe. Every lathe has a limit but yours is far more capable than you can imagine right now, and your tools will unlock it.
