- Mar 20, 2014
- 439
Is the ridgid cutting oil the same stuff they use for threading pipe?
That's correct, you can find it in the plumbing dept. of most home improvement, or hardware stores.
JR49
YesIs the ridgid cutting oil the same stuff they use for threading pipe?
I have an x2 mini mill I use fairly often. I figured machinist jacks would be fairly easy to make and a good way to learn. I'm not quite ready to make them. I need to actually cut a thread first,lol.
Do you think here in panama they use the same numbering system for their metals? Do they call 12l14 , 12l14? Might be a dumb question as I'm sure they do. Is it a world wide standard?
That shines edge on my tool came from honing it. It felt fairly sharp but not perfect so I've still got some improvemets to make.
Any suggestions on useful beginners tools?
Carbide will never do this.
Now this is misinformation, while I realize that many use machines that were designed with HSS tooling in mind and manufacturers gave little thought to future tooling options.
Making a claim that modern carbide tooling will never work is simply wrong. A more honest conversation would reveal the fact that modern tooling that works well is entirely too expensive for hobbyists, there are no tool manufacturers that want to make tools for the "wait until you can get it cheaper on Ebay crowd"
One of the reasons that it is difficult if not impossible too find good US made machines is that the American manufactures saw the writing on the wall 40 years ago when all of the small shops began to disappear. No one in a modern machine shop uses a manual Bridgeport knee mill or a manual small lathe. There is nothing left for hobbyists to buy used. Other Companies have filled that niche.
Why?
This is an advantage that I hadn't immediately thought of, excellent observation!. The links will theoretically conform more readily to smaller Dia. pulleys as well.
