I don't necessarily disagree with anything you said. However, all lathes need to be checked and aligned from time to time and this will make that process quick and painless. I also have no intentions of ever moving it. I may do away with the wheels and/or make some brackets for levelers on the bench. The workbench has many things in it's favor such as the available storage right at the machine and the fact that it weighs 455lbs. empty. Those things put it far ahead of the sheet metal cabinets that these are typically mounted on in my opinion. The top is over an inch thick and made from many laminated strips of fingerjointed hardwood that are sealed. That should help to stabilize it even though I agree that it is likely to move at least some.
Agreed. And far better than it was. I was just sayin..........................Bob
