Ok Terry, I've been obsessing over this for days. I don't want to do it as I just put the lathe in a month ago. Leveling the table...not so bad. Mounting and leveling the lathe (which is not as related to table level as you would think).....not fun. Adjusting/calibrating the lathe and finding the tailstock size is .004 bigger...less fun and so on... Now that I see this is kinda a have to do with these table top mini lathes, it means starting all over. Ugh.
I have a question as I cut/drill all these pieces. Why do you need to bolt the bars that have the adjustable legs to the table top? I mean, they share the center mounting hole that connect lathe to block to table top. My simplified (lazy) version is this;
There will be a plate that covers the mostly open leg of the lathe, but just like the block that the legs are mounted in, I will rely on the center hole to keep it in place. Is there a fault to this reasoning? The pressure of the center mounting hole will keep all the stuff together and inline? No?
