I appreciate the responses! I do understand that this isn't an ideal pathway, but I'm excited about it, and I'm glad to get these kind of responses. So the plans I've been referring to are here:
http://www.modelengineeringwebsite.com/lathe_build.html
I looked around at some different plans and paths, and this seems to be most in line of what I was looking for.
Ray, you think aluminum is sufficient then if I thicken up critical components? You suggested acme rod, so I'm guessing it's recommended to change the lead screw to an acme thread?
David, I'm not sure what you mean by linear bearing rods? Is that the "ball screw"? If so, how difficult is it to install something like that, seems like a hard thing to thread a nut on! Thanks for clarifying the silver steel too! I was under the impression it was a stainless steel, I thought that's what stainless was called when it was first invented, so I just assumed that's what was meant.
I do understand that having a lathe would make this easier, the author of the plans even points out it is needed for some parts. That kind of brings me to the motivation to build one, and also my question of whether it would be more practical to pay to get those parts turned, or just purchase those components and alter the design to fit?
George, thanks so much for sharing that lathe! By the way, I've been reading a lot of what you have to say on this forum, and I'd like to say thank you, as I'm learning so much! Regarding the lathe you pictured, would it be better to try and alter the design to have a similar bed to that one? It seems harder to make a lathe bed like that compared to the two bars, I imagine it would be better to just buy a bed at that point.
Anyway, thanks so far for the comments! Hopefully you guys can take a look at the plans, and let me know what you think!
