If it is 3 phase, change any of the 2 power (pass through if on a RPC) wires to make the motors work in the other direction. If you are using an RPC, the pass through wires should connect to the transformer (R and T), the generated leg is to the motor connection. If using an RPC and the generated leg is connected to the transformer, it will cause voltage sag when starting the motor and the contactor may chatter w/o starting the motor. Contractors are available for $25-45 depending on if they are shipped from China or from the US, just put search the model number, coil voltage, and contact configuration.
I also would check that the wild leg of the RPC is not connected to the transformer, I have seen similar cases where the motor starting drops out because the coil voltage sags on startup. But wouldn't be surprised if the contactors contacts are crispy.
