I will do the job myself next summer. Need the tractor to blow snow this winter, that is the thing with tractors- always seem to "need" them and hard to budget down time ...
Here's some Pics of some of the old tools I sourced for the job after it was botched and I will lap in the valves to the seats but Only After I stone grind and re cut seats and valves, actually bought a few spare new valves as well just in case.
This Old equipment did great work and excellent results on a Buick V 6 and Pontiac V8 heads I did. Sourced all of the guides replacement seats ( if to far gone to grind) pilots and stones specific to the tractor as well since these pics
A tractor head should be about the same difficulty or less.
By diamond cutting and dressing the stones the seat angles and widths can be brought back to factory specs. Also had to source New stone holders since the bearings and guides were worn on the old ones in the kit.
Pretty obvious even from the pic of the tractor head went to the "machine" shop TWICE
Actually after thinking about it ,that picture is at the machinest shop to "show" him that the valve and seat were Still leaking after the 1st job he did...
After the second time and another new head gasket and all the other fun for me of remounting the head bleeding the direct injection etc. I gave up. Until I tear it apart for the 3rd and hopefully final time .
If it isn't functional this time I can only blame myself. Some Good did come out of this, It prompted me to buy more TOOLS even if they are old.
ps I called the valve grinder a Van Norman, It is actually a Van Dorn and was surprised it only had 3-4 tenths run out when I checked the valve chucking with a new valve installed.
