- Feb 8, 2014
- 11,176
The power for the SD boards comes from the big transformer, through the bridge rectifier, and the large blue cap. What switches on the transformer may be a contactor or a solid state relay. Both are used depending on the manufacturer. The solid state relay, next to the fuse block, is probably what switches the transformer. You are going to have to trace some wires. Coming off of the cap, the red wires are positive, and the gray wires are negative. The SD boards are directly wired to the cap.
Remember when I suggested creating an I/O map of everything that is there now?
Not sure why you don't have 5V on the Kanalog board, is it powered up?
