I couldnt wait... i made some little jumpers.
Ive only got the X axis servo driver plugged in. Everything is disconnected from from the other two servo drives.
Pins 14 and 15 are tied to together and connected to pin 11
Press power on and the fans dont come on and the servo motor slowly slowly turns.
press the reset button on the SD and nothing happens. Other than the servo does not get any juice, stops moving only while the reset button is held down.
I would think that the fans turning on would be indication that the SD is on.
Tried the 1.5v battery in series, applied to pin 2. Nothing. Make sure I was doing this right I connected the signal wire to the negative end of the battery and a 1kohm resistor to the positive and touched the number 2 pin.
Not sure what I should try next.
Im not sure if something should be done with A/B jumpers on J2, they where plugged in part of the fagor control box
