Lagun FTV-2s
Awesome. My answer was there and easily found. Thank you again.
Dhal , the one thing I would consider would be to put the mill on the left side of the lathe . Many a time came up when I had to support the end of a long shaft with a makeshift set-up to avoid bar whip . Just a consideration . :) Having the mill located in the corner as shown also limits you on long pieces of material .
I think I was told to angle it earlier in this thread.
How would I use this on my mill? R8 - 1/2" shaft adapter of some sort.........
Did I mess up my drawbar? Either chase it or replace it?
If you still have engagement, keep it. If you have room on the face of the head side, turn it back to effectively move the threads downward. If there's no other way, make a new one on the lathe.
Give me the dimensions as I may have one Dhal from my FTV-2 Lagun . It is sitting in the bedroom being ready to move out .
I took these before I left my shop.
