Lagun FTV-2 Balanced Handles
Re-broaching sounds like the way to go for the X and Y. You may have to fabricate a knee crank or mod a Bridgeport one
The 7 cog ones are hard to find- you might call H&W and see if they happen to have one 1-800-285-5271
...and our pal Mr. Pete has a video on how to do that.
This only lets me load them one at a time.
Have you checked the condition of the coolant sump and pump?
It looks like you have all the parts and just the ball crank knobs are broken. Buy something close and bore/broach to a perfect fit. Or try H-W Machine and see if they've parted any out. If you have a lathe and some type of ball turner, then it might be worth a DIY.
On the Y axis handle one side is completely broken off. One X axis handle is ok and the other the safety feature is stripped out inside.
The oil cup and the ball fitting are both broken off. I am going to have to get them out and replace them. I'm not sure what they oil but must be important. There is even a tag on that side that explains the lubrication procedure.
I have not opened up the base to check out the coolant pump yet. It's on the to-do list. I was able to find a receptacle today so I can actually hook the spindle up to power. Maybe after Christmas I can get that done and see what works and what doesn't.
I know the DRO comes on and seems to read properly but I will have to verify the accuracy. The X axis power feed does not come on so that is also on the list of things to check out.
I will have to look into the 3D printing option also. I would just have to find someone around me that does it. I'm leaning towards buying the ones online. That gives me an excuse to buy a metric broach kit and I have a slight tool addiction so that seems like a win!
