- Dec 18, 2019
- 7,650
Made @mikey's straddle knurler a while back and have made some ok knurls in brass, aluminum and 12L14. I used 25 TPI Formroll knurls.
I have some 303 stainless and would like to make a new razor handle. I chose my 30 TPI knurls to do the knurling. The knurls came out kind of strange, there's almost a darker spiral down the piece. (About 9 turns) The piece was held by a ER32 collet and a live center at the tailstock. For the first time (was this my mistake?) I used the lead screw to feed the knurler towards the chuck. I got a fine knurl going then engaged the lead screw. Used a sulfur based cutting oil. Can someone point me in the right direction? I haven't finished the piece yet, but attached it to the razor head. It needs to be cut to length and have some additional features added. The spiral, which was much much darker when the knurls were cut, is a visual distraction. I scrubbed the handle 3 times - there's still a spiral
This appears to be double knurling? (Not tracking?) The knurl seems really fine. Then I need more initial pressure? Any other tips for knurling 303?
Cut of the knurls and try again? The handle is a little large, so I could make it thinner.
