@Cadillac STS, here you go. Not sure how the picture quality will be. First pic shows all the parts in relative position. You can see that the arms hinge on a stainless steel bushing through which a 10-32 SHCS passes. The bushing is sized to just fit a reamed hole in the outer side plate and the end of the arm. Also visible are the aluminum spacers that are exactly the same width as the arms. You can also see some draw-file marks on the inside of the plate; since the spacers and arms are the same width, to allow the arms to move you must draw file just enough clearance on the side plates. This gives you movement but no discernible play. The screws that pass through the spacers simply thread into the aluminum mounting block that mounts to the cross slide of the lathe.
Disassembled:
Arms: Here you can see that the holes for the half-moon pivoting inserts are round on one side of the arm and slotted on the other side to clear the threaded shaft. The half-moon is O-1 steel. The threaded shaft is 12L14, screw cut to 1/4-28 on top and 1/4-20 on the bottom and Loc-Tited into the lower half-moon insert. Note also that the half-moon cutout in the arms is about 1/8" forward of the center of the arms to provide a bit more leverage; you can crank down with just hand pressure to produce full depth knurls because of this. The plates constrain the arms laterally so this tool is much more rigid than other designs.
How they fit: You can see that there is a reduced diameter below the hex head of the tensioning knob. That diameter just passes between the plates to allow sufficient travel when knurling smaller diameters. Note also that the front of the plates is rounded to allow clearance for larger diameter work pieces.
Not too complicated. Dimensions are not critical in terms of size but you must work with care. By that, I mean all holes are reamed carefully, bushings and spacers are turned accurately, all parts are squared. None of this is difficult and it is a good opportunity to do work with precision.
The nice thing for me was that everything other than the knurls was already in my shop so I paid only for the knurls. This thing took the better part of a week to design and machine but it has served me well for over a decade. It has not mistracked or produced a single bad knurl so I'm satisfied with it.
Hope this clarifies things for you guys.
EDIT: I forgot to re-emphasize a really important lesson I learned.
In order for any feature to be in the exact same location on two or more separate work pieces, you must clamp the pieces together and machine the feature in one operation. For example, if you want the holes at the ends of the arms in the exact same place you have to clamp the arms side by side and square to each other, then drill, then ream. OR, if you want the half-moon holes to be at the same point on the arms, you must clamp them together and drill between those arms. This is the only way to get things exactly the same, and I've already paid for the lesson.
