Thanks Mike for your time and definitely it’s a project I would like to do. I found the FormRol site which is very good with tons of information plus I found a .PDF document about Knurls which I will read to educate myself.
No need for plans but I have these questions:
What is the approx. overall size of the main block?
What is the size of the main bolt? Are the threads coarse or fine?
What is the size of the knurls you have?
Much appreciated
Nicolas
I'm gonna' try to remember what I said the first time but if I miss something, ask, okay?
The mounting block is 6061-T6; 2-1/4" front to back, 1-1/2" high, 1-1/4" thick. The mounting block places the centerline of the knurler on the centerline of the lathe behind the work piece. The bottom of the knurler plate registers on the edge of the cross slide and when the screws are locked down into the T-nuts in the cross slide, the entire knurling tool is solidly held and cannot turn or move unless you want it to. Some users feel that a slight angle of the knurls toward the headstock is desirable; I have not found this to be necessary.
Contrast this to the Sherline tool, which is intended to be mounted loose so the base of the tool can move. Presumably, this is to allow the knurls to track better. My results suggest that a solidly mounted knurler with tight tolerances will form a more precise knurl with very little chance of mistracking if everything is done right.
The main tension screw is 12L14. The threads were 1/4-28 on top with a class 3 fit into the top nut. The bottom thread inserts into the half-moon insert with a 1/4-20 thread, Loc-tited in. 12L14 is more than adequate for this application because there is not an excessive amount of tension on the stud. Over the years, it has performed flawlessly with no sign of wear.
Knurls are from FormRol, 1/2" OD X 1/4" thick X 3/16" ID hole. These knurls are from the EQ series (1/4" wide) instead of the EP series (3/16" wide EPR/EPL 230) that Sherline uses. The knurls I used were the straight EQ 230 pair (fine pitch to reduce mistracking), EQR/EQL 225 and EQR/EQL 230. I had them custom grind a bevel on both sides to allow for axial running and they work well for that.
All knurls above are Circular Pitch knurls. I do not use Diametric Pitch knurls and do not calculate diameters; I just crank down to achieve about a 90% pattern depth and run the knurl. Note that FormRol considers anything deeper than a 90% pattern to be over-knurling that can damage your knurls. These are HSS knurls but I've done a fair number of knurls in stainless steel and have noted no significant wear. If I were to do a lot of it in SS though, I would use cobalt knurls and maybe switch to carbide pins.
Unasked for info:
- Side plates are 1/4" thick mild steel.
- Arms are 5/8" mild steel, milled square to 1/2" X 1/2" X 3" long.
- Top nut is 12L14 steel.
- Delrin washer underneath top nut
- Half-moon inserts are 1/2" OD, O-1 tool steel left in annealed state. No point in hardening them when they run in mild steel with very little movement.
- Aluminum spacers are ~3/8" OD.
Hope this helps, Nicolas.
